Hello, I have a specific request. On our tenant, we need to capture request attributes related to specific namespaces (so, not across the entire environment). In the settings related to request attributes, is there a possibility to select and indicate only where the attributes will come from? Has anyone here already done this and can tell me if it’s feasible or has any tips?
Hi there,
Request attributes are captured on a process. So the closest you can get is only applying the request attribute on certain processes (f.e. apply a tag per namespace). This would instruct dynatrace to ignore other processes.
