Hello.
We need to ingest Promethus SonarQube metric
sonarqube_compute_engine_tasks_running_duration_seconds
which is of type “Summary”.
The doc Prometheus data source reference — Dynatrace Docs says :
Summary
Count part as <metric-key>_count
Total sum part as <metric-key>_sum.count
Individual quantiles split by the quantile dimension indicating the quantile as <metric-key>
but our attempts fail. We keep getting metrics in Dynatrace but all sample to zero. I double checked my SonaeQube metric end point : returns proper non zero metrics.
I don’t understand whether I should specify
prometheus:
- group: sonar metrics
metrics:
- key: my.sonar.prometheus.sonarqube_compute_engine_tasks_running_duration_seconds_count
value: metric:sonarqube_compute_engine_tasks_running_duration_seconds_count
type: count
- key: my.sonar.prometheus.sonarqube_compute_engine_tasks_running_duration_seconds_sum
value: metric:sonarqube_compute_engine_tasks_running_duration_seconds_sum
type: count
metadata:
displayName: Sonar compute engine task running time in seconds. Count.
description: Compute engine task running time in seconds. Count.
unit: Count
metadata:
displayName: Sonar compute engine task running time in seconds. Sum.
description: Compute engine task running time in seconds. Sum
unit: Count
or
prometheus:
metrics:
type: summary
metadata:
unit: Count
Any one scceded to slurp in Prometheus metric of type “Summary” ?
FYI: On managed 1.322.58 OneAgent 1.319.76.
Regards.
