Coloring logs dashboard tile?
In a Managed environment, I’m trying to figure a way on how to differentiate log entries, in the logs dashboard tile. Having a different color for, say, different loglevel’s?
For instance, the last line is an Error, but it’s not easily seen:
I imagine this isn’t possible, as it is for instance for tables in Data Explorer metrics, but is there some hack to do it, before I convert this to a Product Idea?
I managed to do it via the thresholds, does this also apply to your case?
In log widget you can easily overlook ERROR lines (among other lines). I would suggest filtering to f.e. “ERROR” and then count & visualize as standard metric with colored thresholds to alert. Plus add either filtered logs widget or link to filtered logs screen.
@Etienne1
Believe you are talking about metric, not logs…
https://docs.dynatrace.com/managed/shortlink/log-monitoring-log-metrics#create-metric-using-settings “Occurrence of log records—a count of occurrences of log records that match the query”
