Hello everybody
I’m setting up a simple workflow with the following flow:
job_test: executes the query below:
fetch logs, from: -1d
| filter contains(content, “Job_OK_Test”)
| summarize count()
And the result if positive is:
In the next step, send_messafe_ok
I configured the following condition: “{{ result(“job_test”).records | length > 0 }}”
But I believe I’m skipping a step, because it’s not matching and the flow stops with the following error:
Error evaluating custom condition - Attempting to use result of unfinished task. Please make job_test a predecessor of send_message_ok.
If anyone can share something I would be grateful.
Tks
