What is the syntax for custom conditions in workflows?
Hi, I can’t figure out the syntax for adding a Custom Condition in workflows.
I’ve tried using expressions which have been working elsewhere like
"{{event()['event.status']" == 'ACTIVE'`
, but the expression is not being evaluated.
Can anyone tell me the right syntax for this, or show me other examples of how to use Conditions?
Hi @ysulkin,
What you have is almost correct. The custom condition must be an expression as a whole as it should evaluate to a boolean i.e.
{{ event()["event.status"] == "ACTIVE" }}
Hello, where can I find documentation on how to use custom conditions, I need to use a condition for a workflow using DQL, for instance, if I get more than 5 records for an IP, it will creates an issue on Jira otherwise ends the task
Hi @Alejandro_hdez,
Currently, there isn’t specific documentation dedicated to custom conditions. These typically come in the form of Jinja expressions with an optional condition.
For example, your condition might be:
{{ result("execute_dql_query_1").records | length > 5 }}
Please let me know if I can help you further.
