I have been trying to create the following Anomaly Detector configuration:
evaluate the average dt.host.cpu.usage for a host group and alert if it’s above 80%.
The tricky part is that I want to generate a conditional alert based on the value: e.g. 80<cpu<90 generates a warning, cpu>90 generates a critical. I can’t seem to be able to set up the criticality dimension to the event title/properties.
The latest query I have is below, but whenever I include criticality in the dimensions it messes up the result.
timeseries cpu_usage = avg(dt.host.cpu.usage), filter: contains(dt.host_group.id, "XXXX"), by:{host.name,dt.source_entity}
| expand cpu_usage
| fieldsAdd criticality = if(cpu_usage >= 90, "critical", else: "warning")
| fieldsAdd raise_problem = if(cpu_usage >= 80, 1, else: 0)
| summarize raise_problem = collectArray(raise_problem), by: {host.name, timeframe,interval,dt.source_entity, criticality}
George
