At present I am trying to connect to Dynatrace using my Open Telemetry Collector. I need to use the OTLP gRPC protocol for my POC. The configuration I have used is as below:
`exporters:
otlp:
endpoint: https://{environmentid}.live.dynatrace.com/api/v2/otlp:4317
wait_for_ready: false
sending_queue:
enabled: false
tls:
insecure: false
insecure_skip_verify: true`
However I see the the below error when i run my collector using the config above
{"level":"warn","ts":1676323322.198344,"msg":"[core] [Channel #1 SubChannel #2] grpc: addrConn.createTransport failed to connect to {\n \"Addr\": \"rcv415883.live.dynatrace.com/api/v2/otlp:4317\",\n \"ServerName\": \"rcv41584.live.dynatrace.com/api/v2/otlp:4317\",\n \"Attributes\": null,\n \"BalancerAttributes\": null,\n \"Type\": 0,\n \"Metadata\": null\n}. Err: connection error: desc = \"transport: Error while dialing dial tcp: lookup rcv41584.live.dynatrace.com/api/v2/otlp: no such host\"","grpc_log":true}
