However, i get timeout error. I tried using https://{environmentid}.live.dynatrace.com/api/v2/otlp/v1/traces:443 endpoint and got host not found error.
Please note that otlp exporter expect a port at the end of the endpoint string (separated by column)
I appreciate if you could share an example config with otlp exporter (not otlphttp exporter) to be used to export traces to Dynatrace. Thank you
The two error messages you posted would suggest a network issue. Did you verify if the network is working, in particular DNS?
Of course, it could also be a configuration issue, which breaks the hostname (and subsequently DNS resolution). I am not too familiar with the precise syntax of the configuration file and not entirely sure if endpoint is supposed to point to a hostname or a URL.
If it is the latter, I’d assume your configuration is all right (though you said you want to use gRPC, right?). The second URL (with the path) should not be correct, however, as you need to specify the port after the hostname, not after path.
I was just informed that the backend would not support gRPC yet, so you’d need to use HTTP, in which case endpoint takes a proper URL, which should be the base one. Have you tried this already?
