The environment I currently monitor is using Web logic, which is connected to Oracle DB later. I found that some Weblogic has “Connection pool” indicators, and some do not.
I am thinking, is it related to the “connection type”? Because there will be a “connection pool” indicator when using “normal” connection, but not when using “GribLink”.
I wonder if you have ever encountered such a situation?
Is there any other way to get the “connection pool” indicator?
Thank you,
Owen
