Connectivity between Azure Web App and Dynatrace
Good morning,
What kind of network rule is needed when I install the Dynatrace Oneagent extension from an Azure Web App to a Dynatrace Saas?
regards
Hi @ardit
You can find all the necessary information about native information here:
https://www.dynatrace.com/support/help/setup-and-configuration/setup-on-cloud-platforms/microsoft-azure-services/azure-platform/azure-native-integration#expand--how-to-register-the-dynatrace-resource-provider--2
and
Radek
Hi Radek this doesn’t really help :slightly_smiling_face: my question is specifically made to understand if any network rule is needed in case I install Dynatrace Oneagent extension on an Azure Web App that only has outbound IP addresses.
I have not encountered any additional network configuration after configuring the extension on the Azure side. You will need to provide an environment ID and API token in the case of SaaS environments. Once the extension is running, the data will be reported to Dynatrace. In case you would need to update the OA then you have 3 options (easiest manually via AzurePortal).
Radek
