Dynatrace Azure extension installing using ARM template
Hello!
Has anyone tried to install Dynatrace Azure extension using Azure Resource Management template? What was your experience?
Kind regards,
Guntars
I also would like to know the answer to this please
I tried following the Document online, but i keep getting errors, its as if it only works if you are creating a new webapp, but what if i wanted to add DT to an existing one or update the agent?
Any updates to this thread with possible experience with Dynatrace Azure extension installing using ARM template?? Karolina Linda
@Karolina_Linda
Here are documentation articles on how to integrate OneAgent on Azure App Service using the ARM template:
Automatic install using an ARM template
and on how to integrate OneAgent on Azure Functions App Service plan using the ARM template:
Install Dynatrace OneAgent site extension using an ARM template
Let us know if you need more information or if something is missing from our documentation.
