Hello Team,
Is there a way to convert an MDA query into DQL or plot a chart on the dashboard without creating custom metrics?
I’m looking to split metrics from dt.service.request.count by dt.entity.cloud_application_instance. Any insights or suggestions would be appreciated.
Akhil Jayendran
@Akhil-Jayendran Can you please try the below?
timeseries sum(dt.service.request.count), by: { dt.entity.cloud_application }
| fieldsAdd dt.entity.cloud_application.name = entityName(dt.entity.cloud_application)
Hello @p_devulapalli ,
I would like to get the metrics split by pode level (dt.entity.cloud_application_instance) above one is only with workload level I think.
@Akhil-Jayendran I am bit doubtful if this metric can be split by pod, but I could be wrong .
Hi @p_devulapalli Even I have the same feeling, but in the Dynatrace UI under MDA I can split this metric with pod name (service_instance) so I still have the hope we can do it same in the DQL with same metrics or any other metrics.
Does anyone have any insights on this? Is it achievable using DQL?
Hey @Akhil-Jayendran ,
I just wanted to check in and see if you still need help with this. If so, I’d be happy to look into it for you! :blush:
Hi @IzabelaRokita ,
Not really, I think it is not supported
@Akhil-Jayendran not using built-in metics directly, as those do not contain this information. You can query it using spans (if you have Dynatrace SaaS with Traces in Grail), as this is a replacement for MDA in the Gen3. You just need to use a different ID - since service instance is not a common field in Grail.
For example:
fetch spans
| filter request.is_root_span == true
| makeTimeseries count(), by: { dt.entity.process_group_instance }
| fieldsadd dt.entity.process_group_instance.name = entityName(dt.entity.process_group_instance)
See that in action in playground.
