How to create data explorer with metric request count total, splity by host and services
Hi All,
I want create dashboard to export data report csv from there
The question how to create request count total with split by host, services and filter by process group
I have try but still failed :
Please help me
Andra
I think multidimensional analysis might be helpful this time:
You can split per service instance to see in which hosts is running, and filtering by process name.
You can export it as CSV also (right down corner):
If this is not viable to you, maybe DQL can be what you are looking for.
Best regards
Hi AntonPineiro,
I used dynatrace managed version and i cannot see menu DQL
Yes, previously i try on multidimensional but its not clear
My customer want like this :
Split by Service | Dimension as Service - Instance think is right | and for process group from info my customer they want break 3 process group
On multidimensional only can used 1 filter on 2 filter you can’t add same, how ??
How to create like that?
Andra
DQL won’t be an option right now. Your approach is the best one.
I would tag all process groups you are interested in advance. And then, I would filter for that tag, it can be number or process groups you want.
Best regards
Best regards
Hi AntonPineiro,
Is there any other way besides creating tags, to output services, hosts, and tps?
Andra
Maybe using DQL instead but you need a SaaS tenant with Grail enabled.
Best regards
If you need built-in service metric displayed and split by instance, then you have just two solutions - MDA as suggested by @AntonPineiro  or defining calculated service metric having service instance as a dimension. For a dashboard - it must be a calculated service metric.
Hi All,
Thanks its solved, i have confirm about it to my customer
My customer accept it using MDA and split by services:instance used filter by per process group tag
Andra
