cost of the “Browser Monitor or Clickpath” capacity in a dashboard
I want to display the monthly cost of the “Browser Monitor or Clickpath” capacity in a dashboard. I can’t find any elements in dt.system.events as I can for other capacities.
builtin:billing.synthetic.actions.usage_by_browser_monitor:splitBy():sort(value(auto,descending)):limit(20)
Is it possible to convert the query below from the data explorer into a DQL query?
Below is the expected result format in the dashboard, for example
Aurélie
Are you in DPS model?
Looks like RUM and Synthetics cost are not in DQL format.
Best regards
we will have to wait until Synthetics are also in Grail
For now you can always use the DT SDK
* This function will run in the DYNATRACE JavaScript runtime.
* For information visit https://dt-url.net/functions-help
import { metricsClient } from "@dynatrace-sdk/client-classic-environment-v2";
export default async function () {
  const data = await metricsClient.query({
    acceptType: "application/json; charset=utf-8",
    resolution: "1M",
    to: "now/M",
    metricSelector: "builtin:billing.synthetic.actions.usage_by_browser_monitor:splitBy():sort(value(auto,descending)):limit(20)"
  console.log(data.result[0].data[0].values)
  return data.result[0].data[0].values;
you will need to play around a bit with the timestamp and values fields to get the right format you want for the table.
