DQL - Classic metric "billing.full_stack_monitoring.usage_per_host"
I would like to use this classic metric in new dashboard:
builtin:billing.full_stack_monitoring.usage_per_host:splitBy("dt.entity.host")
I have just not seen an equivalent in Grail. Which is equivalent to that metric using non classic selector?
Best regards
I used Account management then looked at full stack monitoring in a notebook.  Here is a dql that may help?
fetch dt.system.events
| filter event.kind == “BILLING_USAGE_EVENT” and event.type == “Full-Stack Monitoring”
| dedup event.id
| summarize billed_gibibyte = sum(billed_gibibyte_hours), by:{dt.entity.host}
| fields host_id = dt.entity.host, host_name = entityAttr(dt.entity.host, “entity.name”), billed_gibibyte
| sort billed_gibibyte DESC
I am sure you have seen this post?
https://community.dynatrace.com/t5/DPS-Cost-Allocation/DPS-Cost-Allocation-Dashboard-UPDATED-v3-3/td-p/268578
This metric is not available and the billing events are the right way to go.
Equivalent DQL query would like using makeTimeseries command:
| filter event.kind == "BILLING_USAGE_EVENT" and event.type == "Full-Stack Monitoring"
| dedup event.id
| fieldsAdd host_id = dt.entity.host, host_name =entityName(dt.entity.host), billed_gibibyte
| makeTimeseries billed_gibibyte = avg(billed_gibibyte_hours) , by: {host_name}
Best regards
