Openpipeline for “User sessions” and “User events” does not offer the “product allocation” step which allows setting a costcenter and product.
Synthetic has a similar issue, you can set a security context directly on the monitor, but you can’t set costcenter and product.
For synthetic tags might work, I just don’t know if it’s classic or primary.tags that need to be set.
I tried to add the cost fields in the process step of the “user sessions” pipeline, that didn’t work since both cost fields seems to be protected.
I can’t tell out teams there exact RUM costs at the moment. For some teams RUM is the majority of their spend, I need to be able to tell them how they are holding up against the agreed budget.
How are you handling this?
