Could not load agent module for Dynatrace OneAgent SDK for C/C++
Getting the Error: Could not load agent module for Dynatrace OneAgent SDK for C/C++: the specified module was not found
when trying to run the sample1.exe (OneAgent SDK for C/C++) on windows.
OneAgent is running and I can’t find out what the problem is.
Thanks for the help in advance.
did you follow the recommended troubleshooting steps?
Please provide the console output for more information.
Yes
2020-07-06 07:13:06.184 UTC [00000620] info [onesdk] Initializing Dynatrace OneAgent SDK for C/C++ …
2020-07-06 07:13:06.200 UTC [00000620] info [onesdk] SDK stub version 1.5.1.4, build date 2019.10.23 12:58:09.
2020-07-06 07:13:06.209 UTC [00000620] fine [onesdk] Preparing arguments…
2020-07-06 07:13:06.213 UTC [00000620] config [onesdk] Options:
2020-07-06 07:13:06.218 UTC [00000620] config [onesdk] Agent active: true
2020-07-06 07:13:06.222 UTC [00000620] config [onesdk] Agent module: ‘oneagentloader.dll’
2020-07-06 07:13:06.226 UTC [00000620] config [onesdk] SDK log level: finest
2020-07-06 07:13:06.230 UTC [00000620] config [onesdk] Additional options:
2020-07-06 07:13:06.235 UTC [00000620] config [onesdk] ONESDK_INTERNAL_CA627667445C40F0_INIT_FLAGS=0
2020-07-06 07:13:06.240 UTC [00000620] fine [onesdk] Loading agent module…
2020-07-06 07:13:06.280 UTC [00000620] info [onesdk] Could not load agent module for Dynatrace OneAgent SDK for C/C++: The specified module was not found
ONESDK initialized: no initialize: The specified module was not found
agent_set_warning_callback: Not initialized.
agent_set_verbose_callback: Not initialized.
I cannot see any suspicious in these log lines. Here are a couple of ideas and questions:
  • The log message looks like OneAgent was not installed. Could you verify that the installation works:
    • oneagentproc.dll must be loaded into the process (this can be verified with Process Explorer)
    • oneagentloader.dll and oneagentsdk.dll must exist on your machine.
  • A reboot after OneAgent installation might be required
  • Is the application running with a debugger attached (from within Visual Studio)?
    • If yes, please try running it as a Release build outside Visual Studio
They exist and work
Didn’t work, getting the same output
Do you see oneagentproc.dll being loaded into the process?
There are some exe calling oneagentproc_27632.dll
but not the Dynatrace-OneAgent-Windows-1.193.170.exe
The application using the C++ SDK must have oneagentproc.dll loaded at runtime. Can you verify that please?
Yes it is
Are any other Dynatrace DLLs loaded into this process?
No there are not
could please attach a screenshot of process explorer where we see the list of loaded DLLs - sorted by “Company Name” (so we see everything by Dynatrace) and displaying the DLL version information?
Hi
this are the dynatrace dlls loaded by sample1.exe
oneagentproc version:1.195.146.90
that was really helpful!
A potential problem could be this “Digital Guardian Agent” that is also present in the process. Multiple agent technologies within a process has caused similar issues in the past. I suggest disabling this other agent (if possible) and see if the problem persists. In any case, you might want to open a support case with us so we can collect logs and additional data about the possible conflict between those agent technologies.
