We have a need for ctc servers to be in full stack to test out our monitoring however when trying to set some of them to full stack we get the following error
initial research indicates that there is a problem with the oneagentctl.exe file , indeed on the servers with the problem it appears to have been “updated” today but has a file size of 0 bytes
D:\Dynatrace\OneAgent\agent\tools>dir D:\Dynatrace\OneAgent\agent\tools\oneagentctl.exe Volume in drive D is Support Volume Serial Number is 0C29-76E6
Directory of D:\Dynatrace\OneAgent\agent\tools
08/07/2026 16:34 0 oneagentctl.exe
Can you please urgently advise how we reinstall this missing exe/dynatrace
I would suggest opening a support ticket.
Best regards
HI @joachimroshan
You can run the OneAgent installer again on the affected servers. A reinstall over an existing installation will repair/replace all agent binaries including oneagentctl.exe without losing configuration:
Option 1: Download the latest installer from your Dynatrace tenant or use the existing installer, Run as Administrator on the affected server, OneAgent-Windows.exe /quiet
Option 2: Copy oneagentctl.exe from a Working Server
If you have another server with a healthy OneAgent installation at the same version:
On a working server, navigate to: D:\Dynatrace\OneAgent\agent\tools\
Copy oneagentctl.exe from the working server, Stop the Dynatrace OneAgent service on the affected server, Replace the 0-byte file with the copied one, Restart the Dynatrace OneAgent service.
Try Option 1 first on one affected host, confirm it resolves cleanly and the service comes back , then roll out to the rest. Keep Option 2 in your back pocket only.
Sujit
