Hi All,
Am getting this error when upgrading Oneagents of the 1.281 versions.
OneAgent installation has failed.
Installer returned error code: 1 If the problem persists, please contact support .
There is no documentation on what this error means.
We retried the upgrade post oneagent restart, still same error.
Has anyone faced this error?
Hi @vishnu_kumar
- You can try updating to the most stable version.
- Share the support archive with Dynatrace support team for further investigation and sooner resolution.
- Uninstall the current version, remove all related previous version files according to the OS Linux or Win
Check the related troubleshooting reference:
Hoping it helps.
BR,
Peter
Hello @vishnu_kumar
If it possible to share log sample for more details.
BR,
Peter
Which log is required @Peter_Youssef ?
Hello Vishnu,
You can either collect the ‘OneAgent Diagnostics’ from GUI or from command mode.
GUI - Go to host settings and you can find it over there. Hope, your server is still communicating to Dynatrace.
Command Line - OneAgent configuration via command-line interface — Dynatrace Docs
Once collected, please share the logs to Dynatrace support team for further investigation.
Hi @vishnu_kumar
You can also follow the provided approach by @Sajarra as an alternative method for collecting logs either to download it locally, or share it with Dynatrace for further analysis.
KR,
Peter
Thanks Everyone for the replies, I used “uninstall” script in the agent files and launched the update.
Worked like charm
