We have agent update problems on some hosts. We can see this on the installer logs:
2022-01-25 10:57:25.895 UTC [b77f9860] info [native] AutoUpdater: Starting update to version 1.231.245.20220112-085307 from: "/var/lib/dynatrace/oneagent/agent/downloads/Dynatrace-OneAgent-Linux-1.231.245.20220112-085307.sh"
2022-01-25 10:57:25.895 UTC [b77f9860] info [native] AutoUpdater: Enough free space (2434 MiB) available on "/opt/dynatrace/oneagent", needed: 1642 MiB
2022-01-25 10:57:25.896 UTC [b77f9860] info [native] AutoUpdater: Free system memory: 3336 MB, required: 200 MB
2022-01-25 10:57:27.229 UTC [b77f9860] info [native] AutoUpdater: Used 184071490 bytes to calculate file sha-256 digest: ee94f81f558808be462dc534d7b8bdf26c916c5f0777494c858b83ecb8ec6235
2022-01-25 10:57:27.230 UTC [b77f9860] info [native] AutoUpdater: Signature verification successful
2022-01-25 10:57:27.230 UTC [b77f9860] info [native] AutoUpdater: Starting: "/var/lib/dynatrace/oneagent/agent/downloads/Dynatrace-OneAgent-Linux-1.231.245.20220112-085307.sh"
2022-01-25 10:57:27.232 UTC [b77f9860] warning [native] AutoUpdater: Setting ambient capabilities failed: Preparation for seting ambient capabilities failed: Failed to set capabilities: error code: 1, error message: Operation not permitted
2022-01-25 10:57:27.268 UTC [b77f9860] info [native] AutoUpdater: Process created successfully, pid: 11236
2022-01-25 10:57:27.268 UTC [b77f9860] severe [native] AutoUpdater: Installation failed: exited normally with code 200
2022-01-25 10:57:27.268 UTC [b77f9860] severe [native] AutoUpdater: Failed to elevate installer process privileges
2022-01-25 10:57:27.268 UTC [b77f9860] info [native] AutoUpdater: Increased delay between autoupdate attempts to 512 minutes.
2022-01-25 10:57:30.109 UTC [b67fb860] warning [native] ScopedCapability: Cannot add capability Capability::SYS_RESOURCE to effective set, it is not present in permitted set.
When running the installer as root, no problems.
Any idea ?
Best regards,
JP
