Hi, every time I try to install dynatrace one agent in one of my boxes it always get stuck in the following step:
16:35:12 Applying settings to file /opt/dynatrace/oneagent/agent/conf/ruxitagent.conf : Tenant Token'
The command that I execute is:
sudo /bin/sh Dynatrace-OneAgent-Linux-1.165.238.sh APP_LOG_CONTEN T_ACCESS=1 INFRA_ONLY=0
Does anyone have a fix or knows what can be happening?
