Crash loop on pods when installing OneAgent
Application-only monitoring
If you get a crash loop on the pods when you install OneAgent, you need to increase the CPU memory of the pods directly in your DynaKube YAML configuration.
Hi darynakovyrina,
We are facing a similar problem.
To which value did you increase?
Regards.
Hi @TomVGW,
I would increase the oneagentresources limits. This is the dafult set in dynakube.yaml. We have changed only the cpu limits from 300ms to 500ms at a client.
oneAgentResources:
requests:
cpu: 100m
memory: 512Mi
limits:
cpu: 300m
memory: 1.5Gi
I hope it helps.
Best regards,
Mizső
Hi @Mizső ,
Thank you for the feedback.
We have now configured the following limits
Unfortunately, it doesn’t seem to help.
Original config was a indeed cpu limit of 300m.
Tom
Hi @TomVGW,
Try to increase gradually. 😉
Best regards,
Mizső
