Limit Resource for OneAgent DeamonSet
Hi all,
We are integrating dynatrace with k8s version 1.20 using DeamonSet.
I see in the yaml file there is a resource limitation for Operator. What about DeamonSet?
You should be able to define the resource limits as we are deploying a DaemonSet (Not a custom resource like the operator).
An example of limiting resources can be found here in the Kubernetes documentation: DaemonSet | Kubernetes
200Mi is probably not enough for the OneAgent - I’d go with similar limits that are recommended for the Operator.
I try to it. But All Oneagent Pods don’t working.
OneAgent Pods status is: CrashLoopBackOff
My dynatrace-oneagent.yaml:
apiVersion: apps/v1
kind: DaemonSet
metadata:
spec:
selector:
matchLabels:
template:
metadata:
labels:
spec:
hostPID: true
hostIPC: true
hostNetwork: true
nodeSelector:
beta.kubernetes.io/os: linux
volumes:
- name: host-root
hostPath:
path: /
containers:
- name: dynatrace-oneagent
image: dynatrace/oneagent
resources:
limits:
memory: 200Mi
requests:
cpu: 100m
memory: 200Mi
env:
- name: ONEAGENT_INSTALLER_SCRIPT_URL
value: https://env/e/700/api/v1/deployment/installer/agent/unix/default/latest?arch=<arch>
- name: ONEAGENT_INSTALLER_SKIP_CERT_CHECK
value: ‘false’
- name: ONEAGENT_INSTALLER_DOWNLOAD_TOKEN
value: ‘’
args:
- ‘--set-network-zone=<your.network.zone>’
volumeMounts:
- name: host-root
mountPath: /mnt/root
securityContext:
privileged: true
apiVersion: apps/v1
kind: DaemonSet
metadata:
spec:
selector:
matchLabels:
template:
metadata:
labels:
spec:
hostPID: true
hostIPC: true
hostNetwork: true
nodeSelector:
volumes:
- name: host-root
hostPath:
path: /
containers:
resources:
limits:
memory: 200Mi
requests:
cpu: 100m
memory: 200Mi
env:
value: ‘false’
value: ‘’
args:
volumeMounts:
- name: host-root
securityContext:
privileged: true
Hi, What is the crash reason? Very likely it runs out of memory at 200Mi - try to increase it to 500Mi or 1G
Oh, I try to increase it to 500M but not running. I will try to increase to more memory. Lol
You can describe the Pod to see what caused the failure.
I see OneAgent Pods status is: CrashLoopBackOff
I try to get event and result as picture:
Thanks. This indicates that either the container host operating system is running out of memory.
The Linux OOMKiller will designate a victim (in this case one of the processes from the OneAgent pods), and that causes the CrashLoopBackoff. So you have to check that your host has sufficient memory available - and then make sure that the limit for the OneAgent is high enough.
The K8s cluster have 3 master node & 3 worker  node corresponding to 3 oneagent daemon. I see that 1 oneagent using a small amount of memory as picture:
Sorry. Noted that: I use deamonset for deployment oneagent
Hello @xuyenpn , removed full token from your reply.
The limits are best set as defined by the Dynatrace operator’s developers.
On the github, you can select the desired version and see the default limits in the example file dynakube
oneAgentResources:
        requests:
          cpu: 100m
          memory: 512Mi
        limits:
          cpu: 300m
          memory: 1.5Gi
You can easly check it for different versions in samples of dynakube.
You can find recommended operator version from documentation page.
Alex Romanenkov
Thanks for your respond.
I removed  full token from my reply.
Noted. I try to using DaemonSet for K8s version 1.16. Don’t using Operator
