Hi team,
How to create exception dashboard in Dynatrace?
Hi team,
Hi @raghvendra,
You have to create a custom metric for the specific exception (by filter) in the MDA. Then you will be anble to vizualize it as a metric on a dashboard. In order to vizualize the metric at leaset one exception (specific one) have to be caputred otherwise you will not find it in the metrics browser. It is required for the alerting also eg. count of the exception in a given time frame.
Maybe other members have a better solution.
I hope it helps.
Best regards,
Mizső
