Create Jira ticket under Epic using Dynatrace
I have to create Jira tickets under certain Epic using Dynatrace and I tried using URL -
“https://{instance-domain}/rest/api/2/issue?id=COETGBAU-2787” under Settings > Integration > Problem Notifications, but nothing is working for me. It should create under the Epic but it keeps on creating under Project.
Hi @sureshvasudevan,
looks like the endpoint you passed to the integration is not valid.
It should have a format like this e.g. /rest/api/2/issue
More Info here
If you want to create the issue under a specific Epic you would need to pass that information in the payload
BR,
Mark
