Hello all,
I want to add a log metric with a custom dimension. I figured out that you need a log processing rule with a matcher and a processor. So far so good. But what will be the new dim name?
Use case example, monitor if there are more then x failed login attempts from a specific IP => need IP as a dimension as input for the metric event?
Any suggestion please?
KR Henk
