Create User Group with Management Zone level permissions
Hi everybody,
I hope someone here can help me here: I would like to create User Groups with permissions just for certain Management Zones in Environments, but in Dynatrace Help for Cluster api v1 (Cluster API v1 | Dynatrace Help) where is  no description how to do it (Actually where is no description for this endpoint at all).
Anybody has an idea? Thanks!
To set management zone permissions call
PUT /groups/managementZones
Sample payload:
 "groupId": "test1",
 "mzPermissionsPerEnvironment": [
   "environmentUuid": "e2888c6a-607e-4c18-b817-f317c10a1aa6",
   "mzPermissions": [
     "mzId": "3827223878816945918",
     "permissions": [
      "VIEW_SENSITIVE_REQUEST_DATA",
      "VIEWER",
      "LOG_VIEWER"
   "environmentUuid": "0f13a010-f581-4b52-915f-746c96a4c977",
   "mzPermissions": []
   "environmentUuid": "65ca87ab-62eb-41ef-9939-d523a3b20cae",
   "mzPermissions": [
     "mzId": "-263036454330135551",
     "permissions": [
      "VIEWER",
      "REPLAY_SESSION_DATA"
   "environmentUuid": "7776be40-7389-42bc-a6dd-e0d4eab206da",
   "mzPermissions": []
   "environmentUuid": "4a74b19f-fd0d-4a92-acc0-bb8e0abb7e1a",
   "mzPermissions": []
   "environmentUuid": "73938789-9f75-4f77-b7d6-54d2dbfbc4a0",
   "mzPermissions": []
   "environmentUuid": "c9a67fe6-8bf8-4bb8-82a1-3ebe8d9ca4d2",
   "mzPermissions": []
Thanks for quick reply. Tested and works.
So, it mean in case I need to have User Group which has to have access just for certain Management Zones inside some Environments, I have to use two steps approach:
1. Create Group
2. Adjust Groups access regarding Management Zones
Correct?
Some remakrs / clarification request if possible:
I had a group defined as:
    "isClusterAdminGroup": false,
    "id": "test",
    "name": "Test",
    "ldapGroupNames": [
      "test"
    "accessRight": {
      "VIEWER": [
        "0d267653-6cb1-429f-a5bb-a04afb247e18",
        "9fe2a41e-b402-4a47-b577-9fa64cadd69c"
      "MANAGE_SETTINGS": [
I used  /groups/managementZones with following content:
 "groupId": "test",
   "environmentUuid": "19000021-de09-4ea6-8076-81c0163c9c7f",
   "mzPermissions": [
     "mzId": "3477049003423719658",
     "permissions": [
      "VIEWER",
      "LOG_VIEWER"
   "environmentUuid": "9fe2a41e-b402-4a47-b577-9fa64cadd69c",
   "mzPermissions": []
   "environmentUuid": "0d267653-6cb1-429f-a5bb-a04afb247e18",
   "mzPermissions": [
     "mzId": "1213888254333099543",
     "permissions": [
      "VIEWER",
     "mzId": "-3471389981007631349",
     "permissions": [
      "VIEWER",
      "LOG_VIEWER"
In UI I see excatly what is defined in the JSON above.
However, output of PUT groups/test shows same content as above (with two Environments)
PUT groups/managementZones/test shows content as expected (including empty “permissions” for not defined Environments and Management Zones (does it mean no access or inheritance from definitions above?
Hm… there’s not resource under `groups/managementZones/test`
If you have a permission set to an environment - you get it to all management zones within an environment.
Sorry for irritation. I mean I see right set up then I use get groups/managementZones/test. However, with get groups/test I see just set up for 2 Environments. Not 3. I am not sure what it mean.
Another Example: If I check on UI for User Group configuration, I see f.e. that MONITORIG SETTINGS feature is checked for Environment 0d267653-6cb1-429f-a5bb-a04afb247e18 but for none of the Management Zones below. Does it mean it is available for all Zones or for none?
No worries. Let me rephrase:
1. GET/groups/managementZones/<groupId> returns only management zones permissions for a given group. Should be same as in UI in “Management Zones” permission section.
2. GET /groups/<groupId> returns only environment level permissions for a given group. Should be same as in UI in “Environment Permissions” section for a group.
In the relation to you example:
Group “test” allows to access:
  1. Environment: “0d267653-6cb1-429f-a5bb-a04afb247e18” (viewer + manage settings)
  2. Environment: “9fe2a41e-b402-4a47-b577-9fa64cadd69c” (viewer)
and additionally to management zones:
  1. Environment: “19000021-de09-4ea6-8076-81c0163c9c7f”
    • MZ id “3477049003423719658” (sensitive, viewer, log viewer)
  2. Environment: “0d267653-6cb1-429f-a5bb-a04afb247e18”
    • MZ id “1213888254333099543” (viewer, session replay)
    • MZ id “-3471389981007631349” (sensitive, viewer, log viewer)
  3. Environment: “9fe2a41e-b402-4a47-b577-9fa64cadd69c”
    • none
Hope if you look this way, you see what’s expected. For example for the environment “0d267653-6cb1-429f-a5bb-a04afb247e18” group allows to:
- viewer (access) to all management zones (env level perm)
- manage settings to all management zones (env level perm)
-  session replay only for MZ “1213888254333099543”
- view sensitive data for MZ “-3471389981007631349”
- log viewer for “-3471389981007631349”
