Management zone filter
Hello everybody! Regarding management zones, I would like to know about the use of management groups to adapt each user to their respective management zone, so that each user only has access to their specific zone. I would like to know if this is possible, I want the zone filter to only appear for users who are supposed to have access to that zone.
I hope you find this post helpful.
https://community.dynatrace.com/t5/Dynatrace-API/Create-User-Group-with-Management-Zone-level-permissions/m-p/163263#M1173
Hi @ArtuD
Yes this is doable from the CMC -- Group management.
When creating the group, you should select the management and respective rights to give.
Is it possible on Saas?
yes, this is possible with SAAS, first you will need to create management zones and then assign only the needed management zone permissions to a user group.
Go to account management page for these permissions.
have a great day!
Yes possible in SaaS
