Creating alert for MSGW status on IBMi
A customer asked us in the IBMi extension, that when some subsystem is in MSGW status, Dynatrace will alert it. At the moment it was configured in the metrics extraction using logs. I would like to know if there is an alternative that is more detailed (For example, that job_user, job_name, etc.). I attached some captures that visualizes an example
I hope you can help us. Thank you in advance
Hello @soportetr
You can proceed with the related alerting through the DQL as per attached resources, it’s easy and straight forward configurations.
Keep up the good work && keep us posted :wink:.
BR,
Peter
