IBM I Extension
Hi all, I am trying to create alerts for specific subsystems statuses when they become inactive. As far as I can tell there is no way to drill down to the status field. If I try to use metric alerts the threshold is a count and should be true or false. If someone has done this and has any tips or builds they could share it would really help! Thank you!
