SNMP v2 extension gathers “Operational Status” of the network interfaces, and it is dimension if.operstatus
If operstatus turns down after being up, it would deserve a possible event. The SNMP extension seems to have only alerts for bandwidth, though.
Is it possible with the current framework to raise an alert if if.operstatus is down? Or not in the if.adminstatus? Being a dimension makes this more difficult?
