I am using the Generic Cisco Device Extension to monitor Cisco devices. I am planning to use a metric event to detect interface link downs. I thought I could achieve this by monitoring the metric “com.dynatrace.extension.network_device.if.status”, but the value of this metric is always 1, and Link Up/Down is defined as a dimension. Is it possible to use this metric to detect link downs as a metric event?
Let me ask a few more questions. In the configuration you provided, the Dimension value is set to “up(1)”. In this case, will it detect a link up or a link down?
