Hi team,
I have a question can monitor a specific namespace in both the and environments/ tenants simultaneously.
The namespace is already fully monitored in tenant1 . Based on what I’ve checked for Remote environment data — Dynatrace Docs , we can pull data for cross-environment dashboards, but can we actually push external requests/metrics directly to a different environment/tenant2?
Looking for some guidance on whether cross-env data pushing is supported for this use case. Thanks!
No, there is no direct support for it.
For data you collect through OpenTelemetry, you can get this working on the collector level to send it to multiple Dynatrace environments. But this will not work with OneAgent data or data collected using other means such as Kubernetes metrics, unfortunately.
