Dears,
Is it possible to have multiple environments for OneAgent?
The use case is that we have a plan to move monitored hosts from one Cluster to another Cluster, and the agent should connect to the available Cluster on that location.
Babar
Dears,
Babar
No you cannot. But :
- you can dynamically switch OneAgent from one to the other environment using oneagentctl
- you can leverage remote environments to get data from one environment to the other
- you can use cross-environment transactions to navigate between environments when troubleshooting a problem spanning 2 or more environments
Hope this helps
Hello @Radoslaw S.
Thank you for your comments.
How to cover the Solaris hosts with this utility (maximum hosts in our case)?
Can you share the documentation link related to the cross-environment transactions?
Is the point # 2 and point # 3 for the same (cross-environment transactions) in your comments?
Babar
Cross-environment tracing : Dynatrace Blog | Dynatrace news
remote environments:
Hello @Radoslaw S.
Thank you for providing the requested information.
Do we have a way to overcome on SUN Solaris limitations related to the oneagentctl?
Babar
