Hi Guys,
Can Dynatrace open an alert for Elasticsearch if the service is down?
Or there is a configuration on Dynatrace, something like custom event API or a log monitoring?
Because previously we had issues with Elasticsearch, services were down, and there was no event alert on CMC, so I had to open the server and check that services.
Yes Dyantrace send critical problem alert if elastic search services are down. I recommend you raise a support ticket to understand why the alerts are not getting triggered to you for this situation.
Hi @techean ,
Can we create custom alert for service elasticsearch?
So we know if the service is down
Yes, it depend if you are using a High premium availability multi cluster managed node. Or simply rely on 3rd party tools or scripts to trigger SMTP or webhook alerts by cron scheduler on server.
Hi @techean ,
We follow the documentation from here , how to create for new schema?
Because on Dynatrace API v2 Settings - Schemas there is just GET on there
Here this documentation doesn’t talk about elastic search service alerts. Check the elastic search part for Premium HA for multi-data centers | Dynatrace Docs, the support for elastic search is covered by Dynatrace.
