Is there a way to pass a custom entity in “Davis anomaly detection” so that it appears as the impacted entity when an problem is generated?
I’ve attempted to use dt.davis.is_entity_remapping_allowed set to false in the event description, along with dt.source_entity as my custom entity (e.g., host@process), but this approach doesn’t seem to be working.
Yes, but dt.source_entity should be a single entity. E.g. the value should be {dims:dt.entity.process_group_instance} or hardcoded CUSTOM_DEVICE-A5C88F64EE123123.
@sia_h Thanks for clarifying! Yes, dt.source_entity needs to point to a single, valid entity. That can be either a dimension reference like {dims:dt.entity.process_group_instance} if event is scoped to a process group instance, or a hardcoded entity ID such as CUSTOM_DEVICE-XXXX if you’ve registered a custom device in Dynatrace.
@AK The key is that the entity you reference must already exist in Dynatrace’s topology — otherwise Davis will ignore it and remap to the closest known entity. If you also set dt.davis.is_entity_remapping_allowed=false, Davis will keep the problem tied to that entity once it’s valid. So the approach works, but only if the entity is properly defined in Dynatrace first.
