Although when the issue occurs, the dt.event.source entity is reported in the description, I still see the environment as impacted, and this doesn’t help the troubleshooting teams.
Thanks, @Peter_Youssef before I proceed to an idea I want to be sure that I am not missing something. Also I want to understand why the “dt.event.allow_entity_remapping”, doesn’t work, because I can see that this flag defines whether the remapping of the target entity is enabled (true) or disabled (false). If the remapping is enabled, Dynatrace can map the event to an entity extracted from the event metadata. If the remapping is disabled or the extraction is not possible, Dynatrace maps the event to the entity specified in the event configuration (for example, a specific host) or to the global environment entity. This property can be written by most event sources, such as Events API, metric events, log events, or Extension 1.0 events.
Hi @DanielS did you manage to get this resolved? I’m facing the same issue with network devices monitored via a custom SNMP extension (v2). I don’t see any option in the extension config to resolve this and I’ve tried various things in the metric event, but without any luck.
That could work, if I knew how to assign an entity ID to an SNMP device created via an v2 extension and map it back to the dt.source_entity property :sweat_smile:
