Custom extension for slow queries
Hi all,
I am trying to build an extension to monitor top 20 slow queries with time taken to execute
Following is my YAML file. in this I am unable to fetch top queries, only I can get response time. Can someone please help me out where I am wrong.
metrics:  - key: oracle.queries.extension.oracle-top-queries    metadata:      displayName: Top queries      unit: Unspecified
  - key: oracle.queries.extension.oracle-top-queries-response    metadata:      displayName: Response times      unit: MicroSecond
sqlOracle:  - group: Top queries    featureSet: “Top queries”    interval:      minutes: 1    ingest: metrics    query: >      SELECT      *      FROM      (SELECT sql_text AS “Queries”, elapsed_time/1000000 AS “Response” FROM sys.v_$sqlarea ORDER BY 2 DESC)      WHERE ROWNUM < 21    metrics:      - key: oracle.queries.extension.oracle-top-queries        value: col:Queries      - key: oracle.queries.extension.oracle-top-queries-response        value: col:Response
Queries should end in 10s by default. Otherwise, the query is killed.
If you check the Oracle extension, in the vars section you have this
vars:
displayName: Heavy query timeout
description: "Default is 10 seconds. Requires ActiveGate 1.275 or newer."
type: text
In the needed queries, the timeout parameter is also added.
- subgroup: topN Queries
        interval:
          minutes: 5
        featureSet: TopN
        ingest: log
        query: >
          SELECT sqlarea.sql_id,
                sqlarea.elapsed_time,
                sqlarea.cpu_time,
                sqlarea.sql_fulltext,
                sqlarea.parsing_schema_name,
                sqlarea.disk_reads,
                sqlarea.direct_writes,
                sqlarea.executions,
                sqlarea.parse_calls,
                sqlarea.buffer_gets,
                sqlarea.rows_processed,
                sqlarea.user_io_wait_time,
                sqlarea.cluster_wait_time,
                sqlarea.concurrency_wait_time,
                sqlarea.application_wait_time,
                sys_context('USERENV', 'INSTANCE_NAME') as INSTANCE_NAME
          FROM v$sqlarea sqlarea
                  JOIN (SELECT sql_id, current_con_id
                        FROM (SELECT area.sql_id, current_con_id
                              FROM v$sqlarea area
                                        JOIN (SELECT SYS_CONTEXT('USERENV', 'CON_ID') as current_con_id from DUAL)
                                            ON area.con_id = current_con_id
                              WHERE (area.last_active_time >= (SYSDATE - NUMTODSINTERVAL(300, 'SECOND'))
                                  OR (area.last_active_time IS NULL
                                      AND area.last_load_time >= (SYSDATE - NUMTODSINTERVAL(300, 'SECOND'))))
                              ORDER BY elapsed_time DESC)
                        WHERE rownum <= 100) sqlarea_int
                        ON sqlarea.sql_id = sqlarea_int.sql_id AND sqlarea.con_id = current_con_id
        timeout: var:long-running-query-timeout
By setting the query duration parameter, you can control the maximum duration of the query execution. For example, if you set it to 30seconds, the query is killed after that time. The code snippets are from the Oracle extension, which demonstrates how this functionality is implemented there.
Hi - I’m following this -
vars:- id: long-running-query-timeoutdisplayName: Heavy query timeoutdescription: "Default is 10 seconds. Requires ActiveGate 1.275 or newer."type: text```
and when referencing it :
- group: some groupfeatureSet: Latestinterval:minutes: 30ingest: metricsquery: |SOME QUERYtimeout: var:long-running-query-timeout
I receive the below warns and error messages:
1: A variable is referenced but is not defined.
2: This variable is defined but is not used within this extension
Could you please share a working example?
