Does Dynatrace provide an official (custom script) extension to monitor SNMP-supported network devices? I intend to collect traffic (I/O), CPU usage, NetPath, etc.
there is an extension called SNMP Autodiscovery, maybe it will suit you
SNMP Autodiscovery monitoring & observability | Dynatrace Hub
You can monitor network devices with SNMP with seevral extensions in Dynatrace:
There is also support for SNMP traps, and you can even develop your own extensions (“scripts”) for specific needs.
NetPath is another issue though. It is proprietary of SolarWinds, so you won’t get much support of it elsewhere. Nonetheless, with things like “Service flow”, and all the functionalities of Dynatarce’s OneAgent, you get a much more detailed and high level view of what is going on…
