We are using the Dynatrace Managed version to monitor our cloud and on-premise environment. We would like to know if there are options to monitor SNMP based devices.
We saw the plug-in being available with Appmon but we would like to know if its possible without Appmon.
There is nothing available at the moment. But you could write Oneagent plugin that will collect data using SNMP. Another option is to collect the data by yourself and push it using API. What is your use case?
We are in the early stages of dynatrace implementation and we just wanted to know the features available in different iterations of the suite. Thank you for the answer; it helps.
Is there any roadmap to enable SNMP monitoring on Dynatrace managed? This is one of the key capabilities to enable end to end monitoring from App --> hardware level. Please confirm..
It is important to note that custom extensions such as this (or custom data through the Dynatrace API) will consume ‘Custom Metric’ licensing.
In the case of SNMP I have developed an extension for basic device health monitoring (UNOFFICIAL).
This will provide metrics for any device listening on SNMP v2/3 and supporting HOST-RESOURCES-MIB and/or IF-MIB. It also adds properties collected from SNMPv2-MIB such as sysuptime and sysdescr.
HOST-RESOURCES-MIB
CPU utilisation
Memory utilisation
Disk Utilisation
IF-MIB (Per Interface)
Network Traffic - Incoming/Outgoing
Network packets - Incoming/Outgoing
Errors - Incoming/Outgoing
Discarded packets - Incoming/Outgoing
You could clone and adapt this to be more device specific if additional device metrics are required.
Hi, can the plugin provided by @Brayden N. be used to collect metrics from Flex Manager/Dell Server manager? The Dynatrace partner who is managing my environment is saying that can’t be used, but the GitHub page where the plugin is stored says “You can fork and adapt this to poll for any SNMP exposed metrics”
