Custom monitoring
Hi
I have a question, do you know on wich language  is designed Dynatrace?
My question is only because i want to do some custom monitoring, for example by one script, but i need to know the dynatrace language or code is designed for that i can to create some script.
Thanks.
Best regard.
I don’t really know which language they used :thinking: But you can create extensions in python (Develop your own Extensions — Dynatrace Docs) and apps in React, TypeScript (About AppEngine | Dynatrace Developer) :slightly_smiling_face:
