Custom Problem Notification
I would like to fetch some data from Synthetic Monitor and want to use that output in Problem Notification.
How we can achieve this ? Kinldy tell.
Shivani
Hi @Shivanish ,
What data do you need to obtain? Do you want to extract them outside of Dynatrace? Please describe your problem in more detail.
Radek
hello @Shivanish
Go to metric then search as synthetic you will get tons of metrics available for synthetic.
For problem notification go to settings --> anomaly detection --> Metric Events (refer doc)
As per @radek_jasinski if you are looking for specific data let us know.
Cheers!
RN
