Synthetic Data Reference Identifier in Problem
I have a synthetic monitor that randomly choose a domain name from an array to access and test. When the monitor generates a problem ticket is it possible to have the value of the domain in the problem name or somewhere when you open the problem ticket?
At the moment to know which domain has failed means you have to execute 4 clicks to the multi-dimensional analysis to see the domain/url at fault
Many thanks
That is a pretty good use case. I dont think there is anything available now that will allow you to do that. You can fiddle with the placeholders for the Alert Integration but even that might not give you what you are looking for:
Never the less, Id recommend tossing in a RFE and maybe that will be something they can start working on!
thanks for the comments, have added something as a suggestion
Can you share with us the RFE link so we can up vote it?
Raised at https://community.dynatrace.com/idea/242841/synthetic-script-user-defined-placeholders-for-pro.html
Up Voted :slightly_smiling_face:
