CVE-2025-54988 & CVE-2025-66516 - Apache Tika Components' Vulverability.
We found a lot of tika components under “/opt/dynatrace-binary/elasticsearch/modules/ingest-attachment/” which are affected from CVE-2025-66516.
Our version is 1.312. Is there any mitigation or suggestions?
Thanks.
If you read this, they recommend to upgrade to version 3.2.2.
Best regards
Hello @eertul,
In this article you’ll have all the needed information on how to report a security vulnerability to the Dynatrace:
Report a security vulnerability
If you’ll follow all the step from it, you’ll get all your questions answered in the support ticket.
As for the both CVE’s you’ve mentioned, I can see already two internal tickets about them. As soon as there will be official communication about them available, you’ll be able to see it in this article:
Dynatrace CVE status (Common Vulnerabilities and Exposures)
Hello @eertul,
One of my colleagues faced the same issue in his monitoring project and fixed it by upgrading the Tika components to the higher recommended versions in a lower environment first. After replacing the JARs under /opt/dynatrace-binary/elasticsearch/modules/ingest-attachment/ and restarting the service, the vulnerability scan cleared.
The recommended versions are:
tika-core → 3.2.2 or later
tika-parser-pdf-module → 3.2.2 or later
tika-parsers → 2.0.0 or later
Sujit
I forgot to write here sorry. As I remember, we verified that the folders are not in use and deleted. So the vulnerability has been cured.
