Java4shell
A new important Java vulnerability has appeared late yesterday: CVE-2026-114938
It affects Java processes, and how the handle Base64. Workarrounds and updates are available.
A quick DQL query shows which processes are affected:
smartscapeNodes "HOST"
| filter os.architecture == "x86"
| traverse edgeTypes: {runs_on}, targetTypes: {PROCESS}, direction: backward
| filter process.bitness == 64
| filter isNotNull(process.software_technologies.java)
| expand tech = process.software_technologies.java
| filter tech[type] == "JAVA"
| fieldsAdd java_version = tech[version], java_vendor = tech[edition]
| parse java_version, "INT:major '.' INT:minor '.' INT:patch ('.' INT:fix)?"
| fieldsAdd fix = coalesce(fix, 0)
| filter (major == 17 and minor == 0 and patch >= 6 and (patch < 21 or (patch == 21 and fix < 1)))
    or (major == 21 and minor == 0 and (patch < 13 or (patch == 13 and fix < 1)))
    or (major == 25 and minor == 0 and (patch < 5 or (patch == 5 and fix < 1)))
    or (major == 27 and minor == 0 and (patch < 1 or (patch == 1 and fix < 1)))
    or java_version == "8u511b33-perf"
| summarize
    processes = count(),
    process_names = collectDistinct(name),
    by: {major, minor, patch, fix, java_version, java_vendor, host.name}
| sort major desc, minor desc, patch desc, fix desc
| fields host.name, java_version, java_vendor, processes, process_names
Dynatrace also posted the Security News page for the issue, it will be updated as soon as we will have more to share:
Thank you both for fast feedback :slight_smile:
Best regards
Hi all
If you have anything similar for Dynatrace Managed, it would be great.
