TIPS : Handling PHP2Shell (CVE-2026-109618/19) - How to Track and Remediate with Dynatrace
:police_car_light: If you are running PHP in production, you likely had a critical priority on your radar a few days ago. If you use Dynatrace, you also have an immediate way to address it.
CVE-2026-109618 and CVE-2026-109619 (“PHP2Shell”): Unauthenticated Remote Code Execution in the PHP core, CVSS 9.2, with active exploitation reported shortly after disclosure.
:white_check_mark: Patched versions: PHP 8.5.12, 8.4.27, 8.3.36, 8.2.35.
:cross_mark: PHP 8.1 and earlier: End-of-life (EOL), no patches available. Migration is required.
The real question isn’t “Are we affected?” but rather “Where, and what remediation work is still left?”
:bar_chart: Packet Perf has released a one-click importable Dynatrace dashboard that provides:
  • Active PHP processes broken down by Kubernetes namespace and server
  • Version categorization: vulnerable, EOL, patched, and unknown
  • Actionable tracking for container images to rebuild, servers to update, and a burn-down curve tracking remediation to zero
Note on coverage limitations: It reads the PHP runtime version — not extensions or Composer dependencies — and cannot detect processes running without OneAgent.
:link: The dashboard is freely available on our GitHub (link).
Feel free to reach out if you have questions about your specific environment.
Thank you for sharing, Dynatrace has created some blog entry in relation this.
Best regards
Hi @AntonPineiro ,
Yes, the article has indeed been released. It provides a good working foundation to move forward.
However, our dashboard is plug-and-play and does not require any specific DQL knowledge or other technical skills to make the necessary decisions.
In less than 5 minutes, you have a complete overview and can start making your decisions :wink:
