Dashboard and Data Explorer - difference between built-in error metrics
I’m building a Dynatrace dashboard and I am confused about the built-in metrics related to errors.
According to the below Dynatrace documentation [1] on built-in metrics, Dynatrace offers the following error rates for use on a Dashboard:
  1. builtin:service.errors.client.rate: Failure rate (client-side errors)
  2. builtin:service.errors.fourxx.rate: Failure rate (HTTP 4xx errors)
  3. builtin:service.errors.server.rate: Failure rate (server-side errors)
  4. builtin:service.errors.fivexx.rate: Failure rate (HTTP 5xx errors)
  5. builtin:service.errors.total.rate: Failure rate (any errors)
[1] Built-in classic metrics — Dynatrace Docs
The documentation is not specified about what these errors are about, therefore I am asking here in the Community forum for clarification.
My questions:
  • What is the difference between client-side errors and HTTP 4xx errors?
  • Likewise, how can I distinguish HTTP 5xx errors from server-side errors?
  • Are the HTTP 4xx errors part of the client-side errors, and are HTTP 5xx errors part of server-side errors?
  • Is the metric “Failure rate (any errors)” then the error rate when considering all 4 error categories (HTTP 4xx, HTTP 5xx, client and server errors)?
Thank you for your support!
Best regards, Bernhard
Hi @bernhard_s,
Could you please check this part of the documentation I think you will find the answers for your questions.
Configure service failure detection | Dynatrace Docs
Best regards,
Mizső
@Mizső   - No, this does not answer my questions. BR Bernhard
The referenced docs page referenced by @Mizső I believe does explain the difference of detected errors and how to configure them if they don’t meet your need.
For example reading the explanation tells me that 500-5xx will always be interpreted as a server error. So 5xx metrics.rate is a server error while 400-4xx (yes there is a typo on that page) is a client error.
Then it also says that missing HTTP response code as client-side errors or server-side. So my naiv assumption is that 4xx is everything from 400-4xx while client side or then server-side (500-5xx), respectively can be more than just the actual 4xx or 5xx errors. E.g. when you also take missing response codes into account.
Answer to
Id therefore say yes to
And yes to:
But maybe @tom_rothschaedl can cross-check this, pls.
