Dashboard for requests separated by instances
Hi team!
I have a problem that I have not found a solution. I have a PowerPC BE server with redhat 6.9 and 2 instances of jboss, one called services1 and the other applications1. Both jboss consume a service called “/bt”.
I need to put in one dashboard the requests from services1 to bt and in another dashboard the requests from applications1 to bt.
The problem is that I can only create metrics to put all the requests from the host in a dashboard, it won’t let me separate them by instances. How can I achieve this? Is there any possible method or workaround?
I suggest you to try with Multidimensional Analysis: Multidimensional analysis — Dynatrace Docs .
For dashboards, you can then create a calculated metric from results: Calculated metrics for Services — Dynatrace Docs
Thank you for the answer! but even the separation in MDV is possible, the creation of the calculated metric specifically is not allow when involving instances.  is there any other way?
