I would like to embed an image in a markdown tile, is it possible ?
No, not at the moment. Only basic text formatting and links are supported in current versions.
Is this functionality being planned or should I submit an Idea?
Image support is planned. Please see our roadmap.
Thanks for the replies @Julius L.,@Roman W.
Hello
It doesn’t work in my environment, something special must be done before using?
The post is from 2021, is this implemented now? IT does not seem to work either as a direct Image or Emoji. Anything special needs to be done? same question was also asked above. The code I use in the Markdown? Any feedback is much appreciated.
## This is a Markdown tile
It supports **rich text** and [links](https://dynatrace.com)
Which the following standard markdown is also supported?
Markdown Reference (commonmark.org)
Thanks for your feedback.
