Max Size of Dashboard
Good day!
Could you tell me what are the limitations of a dashboard in size?
I understand that it is a square 132 by 132 cell, it is correct ?
This is the max size of a dashboard with a markdown tile:
thank you
is it the maximum size of the entire dashboards or only one tile ?
Both :slightly_smiling_face: that tile covers the entire dashboard
